aytwartoofyoroo
[Training Camp] Steering gear gripper
Use Lichuang express cardboard as structural parts,
The main control uses HI3861,
The module has 1 user button and 2 servos (the servos use IO delay to simulate PWM)
The user button is GPIO2
The left servo is GPIO8 and the right servo is GPIO9
When installing, do not put the cardboard on first, but burn the program first. When the button is not pressed, it is in the clamped state, and when it is pressed, it is in the released state.
Updated the PCB diagram, removed the 5V battery interface and high-current LDO module, which are not necessary, leaving the PCA9685 interface (tested, no problem)
Use ubuntu20 system, VSCODE compiler (provided by training camp)
The programming language is developed in C language. I have tested the internal PWM and found that the frequency is not up to standard. There is no way.
I also tested the timer, and it has a minimum period of 10ms, but nothing worked. I finally chose to use the IO simulation method to control the servo. The program defines three PWM functions of the servo for reference.
PCB physical picture
Clamp made of cardboard (cardboard is very brittle, so it works fine)
image.png)
Attachment description
Burn files (no development required, burn and use)
Hi3861_wifiiot_app_allinone.bin
main.c source code (ubuntu development programming file)
main.c
The folder I created here in ubuntuOHOSDOG is my_pwm
For the specific writing method of BUILD.gn, please refer to gn function.txt in pictures 1 and 2.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 12:22:09
