石榴姐
STR-16-30V-BLDC-MDK-GEVK: 1kW, 16-30V motor development board
STR-16-30V-BLDC-MDK-GEVK: 1kW, 16-30V Motor Development board
The STR-16-30V-BLDC-MDK-GEVK is a comprehensive motor development board and a reference design for drive low voltage 3-phase BLDC motors. The power board consists of 6 NTMFS5C604NL MOSFETs for the inverter stage and NCP1034 PWM synchronous buck controller for power conversion. The 3-phase power board is rated for a maximum of 30V DC and consists of all necessary system blocks for a BLDC motor driver. As part of the motor development kit, the power board is compatible with the power Universal controller board enabling high-end control strategies and AI capabilities for industrial motor control. The complete kit is Strata enabled and the graphical user interface can be used to set control parameters for the motor drive.
The STR-16-30V-BLDC-MDK-GEVK comprises of the 1kW, 30V power board, hardware adapter for the UCB, and the Universal controller board (UCB)
For the power board only, visit STR-16-30V-BLDC-MDK-GEVB
Features and Applications
Power board for Motor Development Kit (MDK)
Compatible with the Universal Controller Board (UCB) FPGA/ARM
Fully compatible with Xilinx® development tools for Zynq®-7000
Strata Enabled
Downloadable Trapezoidal control use cases for the UCB
VIN: 16V - 30V DC
Compatible with three-phase BLDC motors
Over current protection (OCP), Over voltage protection (OVP)
Plug-in connector interface for MCU cards (Arduino DUE footprint)
Sensored Trapezoidal control strategy implemented
Strata enabled and available for a quick-start evaluation
Xilinx® development tools and environments are available for the MDK, such as Vitis and Vivado to program the FPGA
Autonomous Mobile Robots
Power Tools
Fans, Pumps, and Compressors
Low voltage motor applications
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 06:40:41
  • EEWORLD University - How to design a single-phase shunt meter using an independent metering ADC
  • How to implement automatic cleanup (WINCE as server)
  • Rectification circuit filtering
  • STC52+DS1302 reads data as FF, help
  • Problems with Tim5
  • How to modify the official firmware of micropython esp8266
