Posts
Resources
21
sjzzlxy posted on 2016-6-3 17:03 Just check this. It will be automatically copper covered without double clicking
How can I remove the red dotted frame after trimming the copper?
This post is from PCB Design
Comments
The copper foil will be automatically covered after it is removed. I personally think it is not necessary to remove the dotted frame!  Details Published on 2016-9-29 09:43
Posts
Resources
22
wufeijian posted on 2016-5-29 09:18 Yes, you can see that there is no copper foil in the dead zone, only an outer frame
Can the previous package be used in 16
Comments
OK  Details Published on 2016-9-29 09:43
OK  Details Published on 2016-9-23 21:44
192
Posts
Resources
23
Longshang Jiangnan Electronics published on 2016-9-10 12:01 Can the previous package be used in 16?
Yes
Personal signaturetbool.taobao.com学习交流
97
Posts
Resources
24
yuye3456 posted on 2016-9-9 22:42 How can I remove the red dotted frame after trimming the copper foil?
Comments
No need to remove it, it won't have any effect, just to tell you that the copper skin has been dug out here  Details Published on 2016-10-27 11:36
97
Posts
Resources
Yes
Posts
Resources
26
I have also encountered this situation. The copper laying frame is displayed, but it has actually been laid. However, due to version issues, it is sometimes not displayed. You can select and remove all the copper laying and try laying it again.
Comments
https://bbs.eeworld.com.cn/forum.php?mod=redirect&goto=findpost&ptid=491237&pid=2023577&fromuid=431426 The above has been solved  Details Published on 2016-10-6 20:50
192
Posts
Resources
27
zzw1995 posted on 2016-9-30 11:24 I have also encountered this problem. The copper laying frame is displayed, but it has actually been laid. However, due to version issues, it is sometimes not displayed. You can select it and lay the copper all...
https://bbs.eeworld.com.cn/forum ... 3577&fromuid=431426The above person has solved it
Posts
Resources
28
You can re-paste, select the copper and then right-click. Click Polygon Actions and then click Repour Selected to redraw the currently selected copper, and click Repour All to redraw all copper.
153
Posts
Resources
29
wufeijian posted on 2016-5-29 09:20 Newly laid copper does not have this problem, only the PCB has been modified, and the outer frame is displayed
AD15 also encountered the problem you mentioned
Posts
Resources
Come and study
192
Posts
Resources
31
sjzzlxy posted on 2016-9-29 09:43 The copper foil will be automatically covered after it is removed. I personally think it is not necessary to remove the dotted line frame!
It does not need to be removed, it has no effect, it is just to tell you that the copper foil has been removed here
Posts
Resources
32
AD17 is the same. Let’s try it now to see if it works well.
Posts
Resources
33
AD17 is also easy to use{:1_102:}
Comments
Just installed, under study  Details Published on 2016-11-30 14:44
192
Posts
Resources
34
chinamy posted on 2016-11-21 18:22 AD17 is also easy to use
Just installed, under study:loveliness:
116
Posts
Resources
To learn
Posts
Resources
36
wufeijian posted on 2016-6-19 15:33 This answer is correct, thank you
I am here to learn, thank you
Posts
Resources
37
192
Posts
Resources
38
1066950103 posted on 2017-1-12 22:54 I am here to learn, thank you
:victory:
Posts
Resources
39
Can copper cladding be placed outside the board frame?
Posts
Resources
sjzzlxy posted on 2016-6-3 17:03 Just check this. No need to double-click to automatically copper-pour
I learned that I uninstalled the ad last year because of this problem
Comments
Reinstall  Details Published on 2017-1-22 16:12
Guess Your Favourite
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
