8387 views|10 replies
Posts
Resources
The OP
How to draw rounded corner differential lines in AD? [Copy link]
It seems that the differential line can only be run at right angles and 45 degrees? Please guide
This post is from PCB Design
Latest reply
My AD9 seems to require CTRL+shift+space   Details Published on 2019-7-15 23:49
Posts
Resources
I use ad9
188
Posts
Resources
Can walk in an arc
Posts
Resources
It seems to be set in the rules.
22
Posts
Resources
Yes, set it in the rule.
96
Posts
Resources
Press shift and space to switch line drawing mode
Posts
Resources
You can set it in the rules
201
Posts
Resources
Press shift+space to switch line drawing mode
Posts
Resources
I heard AD9 is not good
Comments
Shift+space can be used as AD9  Details Published on 2019-7-15 09:05
2w
Posts
337
Resources
wklzsw posted on 2019-7-14 16:51 I heard that AD9 is not good
Posts
Resources
Guess Your Favourite
Just looking around
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
