3303 views|4 replies
Posts
Resources
The OP
PB Export SDK [Copy link]
When compiling a project file in EVC, it reports an error: Cannot open include file: 'pkfuncs.h'. I exported the SDK of pxa270 in PB and generated PXA270_SDK.msi. After installation, pxa270 also appeared in the drop-down list of EVC. When I build again, it still says that pkfuncs.h cannot be found. I would like to ask if my SDK is exported incorrectly or if there is another reason?
This post is from Embedded System
Latest reply
Thank you 91program! It's exactly what I wanted.  Details Published on 2008-8-8 10:04
85
Posts
Resources
It is probably not a problem with the SDK. You cannot find the header file Cannot open include file: 'pkfuncs.h'
Posts
Resources
In the EVC menu: Tools->Options..., select Directoris, and add D:\WINCE500\PUBLIC\COMMON\OAK\INC to the Include files directory.
48
Posts
Resources
I know that there is a file called pkfuncs.h in the PB installation directory C:\WINCE500\PUBLIC\COMMON\OAK\INC, which I manually copied to my test program directory.Changing it to "pkfuncs.h" should work. pkfuncs.h is only used when the test program has hardware operation. I want to add this file to the SDK I exported, because there are many test programs that have hardware operation actions, and I don't want to modify the code one by one. Can it be directly included in the SDK?
Posts
Resources
Guess Your Favourite
Just looking around
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
