917 views|0 replies
489
Posts
Resources
The OP
Wide voltage 12-100V electric vehicle charging power supply application solution H6215L [Copy link]
1. Solution name: Wide voltage 12-100V electric vehicle charging power supply application solution H6215L
2. Solution Brand: Huihai Semiconductor
3. Program Overview:
Electric vehicles have become an important means of transportation for more and more people due to their convenience, environmental protection and high cost-effectiveness. When traveling, we often encounter situations where mobile phones or other electronic devices need emergency charging. At this time, we can use electric vehicle mobile phone chargers to solve this problem. They are plug-and-play and charge quickly.
This article introduces the application of power supply for USB mobile phone chargers in electric vehicles. H6215L, a high-efficiency DC-DC step-down constant voltage chip launched by Huihai Semiconductor, can be applied to this solution and plays an important role in the safe, stable and efficient operation of the charger power supply system. H6215L supports wide voltage input of 12-100V and 2A continuous current, and is widely compatible with mainstream digital products on the market. The chip has high output voltage accuracy, which can be controlled within ±5% constant voltage accuracy, and has line loss compensation function, which is lacking in similar chips on the market, and can solve the problem of output voltage being pulled down due to large output line loss. At the same time, H6215L has built-in multiple protection functions, which can avoid overvoltage, overcurrent, short circuit, high temperature and other situations during the charging process.
4. Features of the solution:
1. Low power consumption, low ripple
2. Output line loss voltage compensation
3. High conversion efficiency up to 95%
4. Built-in 100V high voltage MOS
5. Wide voltage 12V-100V input range
6.Support output voltage adjustable to 3.3V
7. Good linear regulation and load regulation
8. Built-in soft start function (SS), no overshoot at startup
9. Fast dynamic response and high output voltage accuracy (±5%)
10. Typical 2A continuous current and 4A peak instantaneous current
11. With multiple protection functions: over current protection (OCP), over temperature protection (OTP), short circuit protection (SCP)
5. Schematic diagram and DEMO board:
The typical parameters of this application are: input DC12-90V output DC5V2A
(H6215L power supply schematic)
6. Contact information:
15323519289 Pang Sheng
We can provide product information and sample testing, and have technical support. Welcome to consult.
This post is from Release of Information
Just looking around
Find a datasheet?
EEWorld Datasheet Technical Support
Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
快速回复 返回顶部 Return list
