36 views|2 replies
FireRain111
Currently offline
The OP
Published on 2026-3-25 13:58
Only look at the author
Need help with JFE2140 single-ended input low-noise amplifier circuit. [Copy link]
This post is from Analog electronics
Latest reply
I can offer some advice:
Do not imitate the typical application circuits given in the chip's datasheet. Instead, design the circuit according to your own requirements and select appropriate components.
The circuit board is already installed and soldered. Before powering it on for testing, the load must be connected. The first step is to use a multimeter to check the power supply voltage and the DC voltage at various points in the circuit. The second step is to connect a signal source and use an oscilloscope to check the input and output waveforms.
Details
Published on 2026-3-25 16:43
Published on 2026-3-25 16:39
Visited sections |
EEWorld Datasheet Technical Support
Room 1530, Zhongguancun MOOC Times Building,
Block B, 18 Zhongguancun Street, Haidian District,
Beijing 100190, China
Tel:(010)82350740
Postcode:100190
京公网安备 11010802033920号
