5305 views|3 replies
Posts
Resources
The OP
Using extended memory in keil [Copy link]
I have a question: How to use extended memory in Keil, such as
89c51+2764 (8k*8 rom)
in two cases: 1. The program is larger than 4k, such as 6k, so after I generate the hex file
(continuous), how can I burn it into the chip separately?
2. The program is smaller than 4k, such as 2k, but a part of it is put into 89c51, such as 1k
, and the other part of 1k is put into 2764. I can use assembly to achieve it (generate
two .a files, put them into the corresponding chips respectively, and use jump instructions to achieve it),
but how to achieve it in C language?
This post is from 51mcu
Latest reply
But this question is really worth discussing. I only used Keil when it was 51, and I haven't used it for a long time. I don't know how to do it.  Details Published on 2011-3-8 12:26
1w
Posts
Resources
:loveliness:
Personal signaturehttp://shop34182318.taobao.com/
5001
Posts
Resources
I have always adhered to LS's point of view
5001
Posts
Resources
Just looking around
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Room 1530, Zhongguancun MOOC Times Building, Block B, 18 Zhongguancun Street, Haidian District, Beijing 100190, China Tel:(010)82350740 Postcode:100190
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
