Return list
Posts
Resources
21
My board has been soldered~~Thank you for your careful explanation~:kiss:
This post is from Microcontroller MCU
Comments
You're welcome. Let's study together.  Details Published on 2012-7-13 09:16
7249
Posts
192
Resources
22
Posts
Resources
23
Very good, I am going to try it. I think the confusion I have had these two days can be solved. Thank you Changjianze
Posts
Resources
24
Thank you so much OP:)
Posts
Resources
MSP430G2553 is totally OK, thanks to the host, but why do we need to turn on the pull-up resistor?
Posts
Resources
26
P1REN |= BIT3; //Turn on the pull-up. There is no pull-up resistor on the circuit board. The trigger edge is from high level to low level. What does P1REN mean in this sentence? I am using a 149 board and there is no such thing in the register. Please give me some advice! !
Posts
Resources
27
Should I change the 1fff in for to be larger? I changed it to ffff and there is no problem, but there will be a slight delay.
Comments
You can change the value to a smaller value and see if it is larger than 1ff. This is too old. I don’t even remember it. It’s been more than a year.  Details Published on 2013-8-27 20:35
7249
Posts
192
Resources
28
Posts
Resources
29
Just asking, I am using 2553, and it is said that some of the problems are probably caused by different interrupt initialization functions. I use IAR, and the interrupt initialization function is __enable_interrupt(); Now there is a problem, that is, each IO port of 430 can be used as an IO port interrupt, so if other IO ports generate interrupts when executing a certain IO interrupt, how to determine the priority?
Return list
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
