The OP
Published on 2012-5-24 21:23
Only look at the author
This post is from Microcontroller MCU
Latest reply
Just asking, I am using 2553, and it is said that some of the problems are probably caused by different interrupt initialization functions. I use IAR, and the interrupt initialization function is __enable_interrupt(); Now there is a problem, that is, each IO port of 430 can be used as an IO port interrupt, so if other IO ports generate interrupts when executing a certain IO interrupt, how to determine the priority?
Details
Published on 2014-8-26 17:45
Comments | ||
Published on 2012-6-19 00:31
Published on 2012-6-19 08:30
Published on 2012-6-19 10:51
Published on 2012-6-19 23:08
Comments | ||
Published on 2012-6-20 15:05
Comments
I can do it here. I have tried two boards and they all work. I just tried G2231 and it works perfectly. But I have tried MSPG2542 and MSPG2253. It is very confusing to make small modifications.
Details
Published on 2012-6-20 21:04
Comments
MSP430G2553 is totally OK, thanks to the host, but why do we need to turn on the pull-up resistor?
Details
Published on 2013-8-27 09:36
Published on 2012-7-3 12:06
Comments | ||
Published on 2012-7-3 19:19
Published on 2012-7-4 16:23
Published on 2012-7-6 14:20
Comments | ||
Comments | ||
Published on 2012-7-11 20:05
Comments
P1REN is set to internal pull-up. Look at the diagram in the manual. 1 is set to internal pull-up. If the port is connected to a button and no external pull-up is used, the internal pull-up should be turned on. As for whether this sentence can be omitted, look at the schematic diagram of the launchpad.
Details
Published on 2012-7-11 23:04
Comments | ||
论坛测评队员
EEWorld Datasheet Technical Support
Room 1530, Zhongguancun MOOC Times Building,
Block B, 18 Zhongguancun Street, Haidian District,
Beijing 100190, China
Tel:(010)82350740
Postcode:100190
京公网安备 11010802033920号
