4651 views|3 replies
Posts
Resources
The OP
TM4C123G softI2C help please ~ [Copy link]
I used the routine provided by TI and wrote it for pcf8591, but no matter what sub-address I write, I can only read address 0, which is the voltage value of IN0. Help: #include
#include
#include
#include "inc/hw_ints.h" #include "inc/hw_memmap.h" #include "driverlib/gpio.h" #include "driverlib/interrupt.h" #include "driverlib/pin_map.h" #include "driverlib/ sysctl.h" #include "driverlib/timer.h" #include "driverlib/uart.h" #include "utils/softi2c.h" #include "utils/uartstdio.h" // // The I2C slave address of the AT24C08A EEPROM device. This address is based // on the A2 pin of the AT24C08A being pulled high on the board. // //********************************************** ***************************** #define SLAVE_ADDR 0x48 #define STATE_IDLE 0 #define STATE_WRITE_NEXT 1 #define STATE_WRITE_FINAL 2 #define STATE_WAIT_ACK 3 #define STATE_SEND_ACK 4 #define STATE_READ_ONE 5 #define STATE_READ_FIRST 6 #define STATE_READ_NEXT 7 #define STATE_READ_FINAL 8 #define STATE_READ_WAIT 9 static tSoftI2C g_sI2C; static uint8_t *g_pui8Data = 0; static uint32_t g_ui32Count = 0; static volatile uint32_t g_ui32State = STATE_IDLE; void InitConsole(void) { SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX); SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC); GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); UARTStdioConfig(0, 115200, 16000000); } //************************************************ ******************************* // // The callback function for the SoftI2C module. // //***** *************************************************** ********************** void SoftI2CCallback(void) { SoftI2CIntClear(&g_sI2C); switch(g_ui32State) { case STATE_IDLE: { break; } case STATE_WRITE_NEXT: { SoftI2CDataPut(&g_sI2C, *g_pui8Data++); g_ui32Count--; SoftI2CControl(&g_sI2C, SOFTI2C_CMD_BURST_SEND_CONT); if(g_ui32Count == 1) { g_ui32State = STATE_WRITE_FINAL; } break; } case STATE_WRITE_FINAL: { SoftI2CDataPut(&g_sI2C, *g_pui8Data++); g_ui32Count--; SoftI2CControl(&g_sI2C, SOFTI2C_CMD_BURST_SEND_FINISH); g_ui32State = STATE_SEND_ACK; break; } case STATE_WAIT_ACK: { if(SoftI2CErr(&g_sI2C) == SOFTI2C_ERR_NONE) { SoftI2CDataGet(&g_sI2C); g_ui32State = STATE_IDLE; break; } } case STATE_SEND_ACK: { SoftI2CSlaveAddrSet(&g_sI2C, SLAVE_ADDR, true); SoftI2CControl(&g_sI2C,SOFTI2C_CMD_SINGLE_RECEIVE); g_ui32State = STATE_WAIT_ACK; break; } case STATE_READ_ONE: { SoftI2CSlaveAddrSet(&g_sI2C, SLAVE_ADDR, true); SoftI2CControl(&g_sI2C, SOFTI2C_CMD_SINGLE_RECEIVE); g_ui32State = STATE_READ_WAIT; break; } case STATE_READ_FIRST: { SoftI2CSlaveAddrSet(&g_sI2C, SLAVE_ADDR, true); SoftI2CControl(&g_sI2C, SOFTI2C_CMD_BURST_RECEIVE_START); g_ui32State = STATE_READ_NEXT; break; } case STATE_READ_NEXT: { *g_pui8Data++ = SoftI2CDataGet(&g_sI2C); g_ui32Count--; SoftI2CControl(&g_sI2C, SOFTI2C_CMD_BURST_RECEIVE_CONT); if(g_ui32Count == 2) { g_ui32State = STATE_READ_FINAL; } break; } case STATE_READ_FINAL: { *g_pui8Data++ = SoftI2CDataGet(&g_sI2C); g_ui32Count--; SoftI2CControl(&g_sI2C, SOFTI2C_CMD_BURST_RECEIVE_FINISH); g_ui32State = STATE_READ_WAIT; break; } case STATE_READ_WAIT: { *g_pui8Data++ = SoftI2CDataGet(&g_sI2C); g_ui32Count--; g_ui32State = STATE_IDLE; break; } } } //********************************************** ********************************** // // Write to the Atmel device. // // *************************************************** *************************** void AtmelWrite(uint8_t *pui8Data, uint32_t ui32Offset, uint32_t ui32Count) { g_pui8Data = pui8Data; g_ui32Count = ui32Count; /*if(ui32Count != 1) { g_ui32State = STATE_WRITE_NEXT; } else { g_ui32State = STATE_WRITE_FINAL; }*/ SoftI2CSlaveAddrSet(&g_sI2C, SLAVE_ADDR | (ui32Offset >> 8), false); SoftI2CDataPut(&g_sI2C, ui32Offset); SoftI2CControl(&g_sI2C, SOFTI2C_CMD_BURST_SEND_START); while(g_ui32State != STATE_IDLE) { } } void AtmelRead(uint8_t *pui8Data, uint32_t ui32Offset, uint32_t ui32Count) { g_pui8Data = pui8Data; g_ui32Count = ui32Count; if(ui32Count == 1) { g_ui32State = STATE_READ_ONE; } else { g_ui32State = STATE_READ_FIRST; } SoftI2CSlaveAddrSet(&g_sI2C, SLAVE_ADDR | (ui32Offset >> 8), false); SoftI2CDataPut(&g_sI2C, ui32Offset); SoftI2CControl(&g_sI2C, SOFTI2C_CMD_SINGLE_SEND); while(g_ui32State != STATE_IDLE) { } } void Timer0AIntHandler(void) { TimerIntClear(TIMER0_BASE,TIMER_TIMA_TIMEOUT); SoftI2CTimerTick(&g_sI2C); } void main(void) { uint8_t pui8Data[16] = {3}; uint8_t pui8DataGet[16] = {0}; uint32_t ui32Idx; SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB); SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0); GPIOPinTypeI2C(GPIO_PORTB_BASE, GPIO_PIN_2 | GPIO_PIN_3); memset(&g_sI2C, 0, sizeof(g_sI2C)); SoftI2CCallbackSet(&g_sI2C, SoftI2CCallback); SoftI2CSCLGPIOSet(&g_sI2C, GPIO_PORTB_BASE, GPIO_PIN_2); SoftI2CSDAGPIOSet(&g_sI2C, GPIO_PORTB_BASE, GPIO_PIN_3); SoftI2CInit(&g_sI2C); SoftI2CIntEnable(&g_sI2C); TimerConfigure(TIMER0_BASE, TIMER_CFG_PERIODIC); TimerLoadSet(TIMER0_BASE, TIMER_A, SysCtlClockGet() / 40000); TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT); IntMasterEnable(); IntEnable(INT_TIMER0A); TimerEnable(TIMER0_BASE, TIMER_A); InitConsole(); while(1) { UARTprintf("SoftI2C Atmel PCF8591 example\n"); UARTprintf("Write:"); for(ui32Idx = 0; ui32Idx < 1; ui32Idx++) { / /pui8Data[ui32Idx] = ui32Idx; UARTprintf(" 0x%02x", pui8Data[ui32Idx]); } UARTprintf(" \n"); AtmelWrite(pui8Data, 0, 1); AtmelRead(pui8DataGet, 0, 1); UARTprintf("Read(0) :"); for(ui32Idx = 0; ui32Idx < 1; ui32Idx++) { UARTprintf(" %02x", pui8DataGet[ui32Idx] ); } UARTprintf("\n"); UARTprintf("Done.\n\n"); SysCtlDelay(SysCtlClockGet() / 2 / 3); } }"); for(ui32Idx = 0; ui32Idx < 1; ui32Idx++) { UARTprintf(" %02x", pui8DataGet[ui32Idx] ); } UARTprintf("\n"); UARTprintf("Done.\n\n"); SysCtlDelay(SysCtlClockGet() / 2 / 3); } }"); for(ui32Idx = 0; ui32Idx < 1; ui32Idx++) { UARTprintf(" %02x", pui8DataGet[ui32Idx] ); } UARTprintf("\n"); UARTprintf("Done.\n\n"); SysCtlDelay(SysCtlClockGet() / 2 / 3); } }
This post is from Microcontroller MCU
Latest reply
This post was last edited by Study_Stellaris on 2014-4-30 08:55 I wanted to use this before, but later found it too complicated, so I wrote one myself. I2C is very simple if you can use an oscilloscope to see the waveform. You can first verify it one function at a time. Then look at the waveform and timing.   Details Published on 2014-4-30 08:54
59
Posts
Resources
You can use an oscilloscope to capture the waveform and determine whether the data sent is correct. It is more convenient than analyzing code problems.
1934
Posts
31
Resources
Is there anything wrong with the hardware circuit? Does I2C have pull-up?
1801
Posts
Resources
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
