2076 views|0 replies
2542
Posts
Resources
The OP
Share how IAR generates the required debugging format [Copy link]
I often see people asking this. It is actually very easy to set up. There are only a few steps:
Right click on the project and select options
Then click Linker in the left column
In the Linker tab, select the first item output
Check the option under Output file
and change the output file name suffix to what you need, such as .hex.
In the Format option box, select Other,
Output and select inter-extneded and it's OK (set as needed)
This post is from Microcontroller MCU
Guess Your Favourite
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
