Breeze block circuit using reactor to reduce voltage
Source: InternetPublisher:Lemontree Keywords: Reactor MDASH Updated: 2021/03/26
The circuit is shown in Figure 3-2. That is, connect another reactor in series to the original reactor speed regulator circuit . The reactor can be
the choke coil on the TV, or you can make your own: use eg. A high-strength enameled wire of about 3mm is wound with 200-300 turns on an M6mm bolt with a length of 40-50mm
, and the insulation is properly handled.
- A simple magnetic switch circuit sharing
- Design and selection of electric control valve system drive
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Build a glove-controlled robotic arm
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Motor control circuit for starting and running without phase loss
- Design and analysis of wire control circuit
- Electric vehicle battery charging protection circuit
- Design and production of no-load automatic power-off device for household power supply
- Simple disconnection burglar alarm
- Rice mill circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Water and electricity saving infrared control circuit
- Photocell trigger control circuit
- Boiler control circuit
- Stapler control circuit
- Simple quick charger
- Circular chasing colored light circuit
- Simple buzzer circuit 1b
- SE9518 Holiday Lights ASIC
