Thermometer circuit with temperature compensation
Source: InternetPublisher:qoistoochee128 Keywords: temperature compensation op amp Updated: 2021/01/22
The circuit of a humidity measuring instrument with temperature compensation is shown in Figure 5-44
. When 0%.~100%RH, o-lov is output accordingly.
The output signal of IH-3605 is processed by the operational amplifier Al, so that at o%
RH, the output is ov (the voltage output by South RP1
is equal to the voltage output by 0% RH); at 25℃, the output of 100%RH
is iov . The Ptl00 platinum resistor is a temperature sensor, which is
amplified by the operational amplifier A2 and outputs a signal proportional to the temperature. Ptl00
and RP3 and two lOk resistors form a measuring bridge, and its working
voltage is provided by the op amp Al output to meet the compensation needs. A3
is an adder that adds the amplified humidity signal and the temperature compensation signal
(taken from RP4), and its output voltage is the temperature
compensated output voltage.
- New function added to MF-47D multimeter - infrared remote control detection
- DIY Metal Detector
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Simple and practical motor short circuit tester
- Simple electric tachometer
- Design of blood analyzer
- How to Use a Radio as a Metal Detector
- Four logic probe circuit diagrams
- Low resistance connection tester circuit diagram sharing
- Electric vehicle luminous voltmeter with undervoltage alarm
- Machine tool maintenance bearing fault detection circuit
- Three-phase alternating current detection circuit
- Three-phase AC power supply phase sequence detection circuit
- Gas concentration sensing detection circuit
- A5349 type AC smoke detection circuit - block diagram
- A5348 smoke alarm detection circuit - typical application
- ADM690~ADM695 constitute a detection circuit (1)
- Multi-light sensor Brinell hardness detection circuit
- Ray detection circuit
- Combustible gas and toxic gas dual-purpose detection circuit
