Component withstand voltage measuring instrument circuit
Source: InternetPublisher:elleny Keywords: Measuring instrument BSP Updated: 2021/07/19
In the electronic manufacturing process, it is often necessary to measure
the back voltage of transistors, diodes, voltage regulators, thyristors, etc. and the withstand
voltage of capacitors. To this end, this section introduces a simple withstand voltage measuring
instrument. Its output voltage is continuously adjustable, up to 1500v.
Here's how it works.
The measuring instrument circuit is shown in Figure 5-27.
The 6V voltage output by transformer T is rectified by VD5 and filtered by C3, and then is provided
to the base voltage of the adjustment tube VT. Adjusting RP can control
the conduction degree of VT, that is, controlling the voltage of collector point M
to change between 4-1400y. The high voltage winding outputs 500v voltage. By C. , VD1 ~ VD4 composed of voltage doubler rectifier circuit rectification, G filter output
1400V high voltage. During measurement, the device under test is connected between M and N, the resistance of RP is adjusted small, the base potential of VT decreases, and the potential of point M increases.
Until the milliamp meter indicates the rated reverse current of the tube under test (the low-power tube under test is less than 0.1 ImA, and the high-power tube is preferably less than ImA). At this time,
the voltage value indicated by the voltmeter is the back pressure under the reverse current. When using a large value resistor, connect the resistor between M and N. Divide the voltmeter reading
by the milliammeter reading, or R=V/I. Each time it is used up, the special RP reaches the maximum, causing the output voltage to return to the lowest point voltage of 4V.
- How to test whether the multimeter is working properly
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Bat sound detection circuit
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Analysis of valid and fault conditions of differential signals
- Infrared detector
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- 1.5V and 9V battery tester circuit diagram
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- Differential amplifier circuit
- Motor forward and reverse control wiring diagram (2)
- Motor overcurrent protection circuit
- Voice controlled flash LED light circuit diagram
- Electric massager circuit
- Inpatient pager circuit
- Chicken supplementary light to increase egg production rate circuit
- Poultry warming temperature control circuit
- Junction field effect transistor mixer circuit
- Varactor Diode Frequency Modulator
- Guest arrival signal recognition circuit
