Cable breakage measuring instrument circuit
Source: InternetPublisher:无人共我 Keywords: measuring instrument cable Updated: 2021/02/12
This device uses a single probe to test whether multiple paths are connected or disconnected and indicates which
end is broken, as shown in Figure 5-25.
Components such as 4060 form a 20kHz oscillator, and the connected 100kfl and
200pF resistor-capacitor components can change this frequency. Each output of the IC, such as Q3 and Q4,
can drive a light-emitting diode or a piezoelectric buzzer to provide necessary indications. This
circuit is installed in a metal box. Hold the cable with one hand and
the tester with the other hand, and touch each pin of the cable with the probe in sequence . If the pin is
connected, stray capacitance will reduce the tone frequency.
Perform the same test on the other end of the cable . The break should be at the end of the frequency that is least affected by stray capacitance
. Touch one pin of the cable with the probe and hold the other end of the cable with your other hand
to check one-on-one. If the cable is intact, the oscillator will stop oscillating. Short circuits in the internal coils of motors and large inductors can also
be checked by comparing them with each other.
- Make a Simple Darkness Detector Circuit
- How to Measure Turbidity of Liquids Using Arduino
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Simple electric tachometer
- Design of wireless meter reading system based on DSP
- Temperature-frequency conversion circuit composed of CD4046
- Leakage Tester
- Homemade LED digital display photovoltaic meter
- Electric vehicle luminous voltmeter with undervoltage alarm
- Use LM3915 to make a practical audio power meter
- Three-phase alternating current detection circuit
- Object presence and displacement detection circuit
- Piezoelectric sensor detection circuit
- Underwater acoustic sensor detection circuit
- Light detection circuit with output filter to reduce noise
- and light detection circuit
- Differential light detection circuit
- Light sensor particle size distribution detection circuit
- Photoelectric pulse detection flying object injection speed detection circuit
- Human body detection circuit for infrared sensor
