A-3-7 air compressor control circuit
Source: InternetPublisher:萌面大虾 Keywords: Air compressor control circuit BSP pressure gauge Updated: 2020/06/28
Air compressors (air compressors) are electrical equipment commonly used in factories and are generally controlled by electric contact pressure gauges .
The circuit is shown in Figure 5-1. The circuit can be operated automatically and manually.
In the figure, KP is an electric contact pressure gauge . When the air pressure reaches the upper limit (such as 0.6MPa), contacts 1 and 3 are closed;
when the air pressure begins to fall below the lower limit (such as 0.4MPa), contacts 1-2 closure. Through the control circuit ,
the pressure in the gas storage tank can always be maintained within the required range of 0.4~0.6MPa.
- Detailed explanation of the working principle of the parking light circuit
- Audio Adapter Cable - Upgrading Car Audio with MP3 Player
- DIY a practical audio-visual doorbell
- Hot wire spark plug control circuit
- Ways to deliver more than 100A to ADAS processors
- Four water tower control schematic diagram
- Differential voltage or differential current alarm
- Micro infrared receiver module PIC-12043S circuit diagram
- Catillac luggage compartment closing circuit diagram
- Low cost alarm circuit
- Motor overcurrent protection circuit
- Analysis of rectifier circuit types and principles
- Agricultural temperature control circuit
- Egg warming circuit
- Farmland drainage automatic control circuit
- Domestic KD8041 integrated phase locked loop
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Audio function generator composed of ICL8038
- Voltage-controlled voltage source second-order band-pass filter circuit
