Circuit diagram of 70W stereo power amplifier based on ICSTA550
Source: InternetPublisher:桂花蒸 Keywords: Power Amplifier Stereo Updated: 2024/06/24
Here is the circuit diagram of a 70W stereo power amplifier built using single power supply ICSTA550. The circuit is simple and requires few additional electronic components to support the working of ICSTA550.
This power stereo amplifier uses a bipolar/symmetrical power supply. Since the negative supply range is only -22V maximum according to the datasheet, you can use a +/-20V to +/-22V supply. Don't forget to install a heat sink on the power ICSTA550 to prevent overheating. ? With the characteristics possessed by this IC, the audio output produced will not disappoint.
About STA550:
The STA550 is a fully integrated power module designed to implement BASH? amplifiers when used in conjunction with the STABP01 digital processor.
feature:
A single chip bridge stereo amplifier for bash? Architecture
55+55w output power @rl=4/8, thd=0.5%
70+70w output power @rl=4/8, thd=10%
High dynamic preamplifier input stage
Externally programmable feedback compressor
AC coupled input to class AB bridge output amplifier
Precision rectifiers for driving digital converters
On/off sequence/timer with mute and standby functions
Proportional overpower output current to limit digital converter
Absolute power bridge output transistor power protection
Absolute output current limit
Integrated thermal protection)
Power overvoltage protection
Flexiwatt power pack with 27 pins
- Share a mini piano circuit
- Field effect tube amplifier circuit with beautiful sound
- Make the most beautiful sound with the least money
- Make a pocket amplifier with 8550 and 8050
- 18-inch large speaker
- LM4903/4905 high gain audio amplifier circuit
- Auxiliary audio power amplifier circuit using LM4732
- 2W×2 power amplifier circuit using LM1877
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Audio amplifier circuit of the Expo flowerpot speaker
- Qorvo adds GaN power amplifier
- DC tube amplifier working in Class B
- BTL audio power amplifier integrated circuit
- TDA7240A power amplifier circuit diagram
- TDA1701 power amplifier circuit diagram
- TDA1554Q power amplifier circuit diagram
- TDA1553Q power amplifier circuit diagram
- TDA1516Q power amplifier circuit diagram
- TDA1510A power amplifier circuit diagram
- STK443 power amplifier circuit diagram
