Stereo tube amplifier circuit diagram based on 6SQ7-GT and 6V6-GT
Source: InternetPublisher:ghaytweyhtoo Keywords: amplifier circuit tube amplifier Updated: 2024/01/08
This is a circuit diagram for a stereo tube amplifier using 6SQ7-GT and 6V6-GT. The tube amplifier circuit uses a total of 5 power vacuum tubes. This diagram is based on the output section design of a typical late 1940's vintage AM Trutone radio with 6 valves. Output will be 4 watts per channel (2x4W stereo tube amplifier)
Parts List:
R1A & B = 500K dual potentiometer
R2, R6 = 1M1/2W
R3, R7 = 470K1/2W
R4, R8 = 220K1/2W
R5, R9 = 330, wirewound or metal oxide 2W
R10 = 750, wire wound 20W
C1, C4 = 200pF/600v
C2, C5 = 47nF/600v
C3, C6 = 22uF/25v
C7 = 47uF/450V
C8 = 33nF/450V
C9 = 10nF/1400v
Power transformer, T1
Primary = 117v 60 cycles
Second. 1 = 600v CT @ 80mA
Second. 2 = 5v @ 2A
Second. 3 = 6.3v @ 4A
Audio output transformer T2, T3
Primary (impedance) = 3300 @ 400 cycles
Secondary (impedance) = 4 or 8 @ 400 cycles
Electron tube:
6SQ7-GT
6V6-GT
5Y3-GT – Full Wave Vacuum Rectifier
Things to note about stereo tube amplifiers:
Don't forget about connecting cords, sockets, switches and the case or circuit board. All tubes are octagonal and require an octagonal socket.
For optimal audio reproduction, speakers with 90db/watt or higher efficiency are required.
Shield any connecting wires used in the signal path between the input jack and the first audio tube.
A choke with a DC resistance of approximately 750 ohms can replace R10.
R10 generates a lot of heat and requires attention to its placement. I applied a large adjustable wirewound resistor to this and mounted it above the chassis. The choke in its place will provide better performance and be more similar to the electromagnetic field in the prototype.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Tutorial on making a MIDI arpeggio synthesizer
- Single-ended Class A amplifier using gallstone composite tube design
- FU-7 Tube Amplifier Homemade
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- Design and production of NE5532+TDA1521 amplifier
- Dual power supply audio power amplifier circuit composed of LM3875
- LM4902 differential input audio amplifier circuit
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Horseshoe gallbladder preamplifier circuit
- 20W OCL power amplifier circuit
- High performance antenna amplifier circuit c
- Pulse amplifier circuit using optocoupler
- recording amplifier circuit
- Symmetric amplifier circuit
- 60W UHF amplifier circuit
- Temperature compensated logarithmic amplifier circuit
- Power amplifier circuit that eliminates transient distortion
- Power amplifier circuit with bass boost compensation
- Op amp driven power amplifier circuit
