Simple multi-tone alarm circuit diagram sharing
Source: InternetPublisher:MartinFowler Keywords: Alarm circuit LM380 MC1458 Updated: 2024/06/07
This is the simple multi-tone alarm circuit diagram. This is a low-cost circuit, simple and easy to build. The main components of this circuit are based on dual op-amps MC1458 and LM380. The two op-amps inside MC1458 are used to generate square and triangle waves. LM380 is used to amplify the output. The first op-amp IC1a is connected as an astable multivibrator and the second op-amp IC1b is connected as an integrator to form the square wave triangle.
The two outputs square wave and sine wave can be selected using switch S1 to the input of IC2, which amplifies it to drive the speaker. POTR4 can be used for tone adjustment.
Simple multi-tone alarm instructions
IC1a and IC1b are identical. So their power supply is common. Pin 6 of IC2 (inv input) is not connected.
C1 and C2 are ceramic capacitors, and C3 is an electrolytic capacitor.
A bipolar power supply is needed here. All it takes is a center tapped transformer, a bridge diode, and an electrolytic capacitor. You can search for circuits on this site
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Model rocket launch controller circuit
- Peripheral circuit of automotive motor controller power supply chip
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- How to set up a cheap beam break sensor control distance scene using a reflector
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Design and analysis of the principle of automatic power-off switch during power outage
- Simple three-phase motor phase loss protection circuit
- Homemade short circuit alarm device
- "Watchdog" anti-theft alarm circuit
- Language reversing alarm circuit c (1)
- Lost child alarm circuit a
- Touch alarm circuit for coronary heart disease patients
- Baby bedwetting voice alarm circuit
- Infant bedwetting alarm circuit
- Water full alarm circuit three
- Water full alarm circuit 2
- Inductive high voltage alarm circuit 4
- Inductive high voltage alarm circuit three
- One of the inductive high voltage alarm circuits
