Home > Audio/Video Circuits >Audio Amplifier Circuits > 35W power audio amplifier circuit based on LM391
Source: InternetPublisher:aytwartoofyoroo Keywords: Amplifier circuit audio amplifier circuit Updated: 2024/06/03
Here is a 35W power audio amplifier circuit based on LM391. The inductor L1 consists of 20 coils with a line thickness of 0.9mm and a round resistor R16. Transistors Q3-4 are the final amplification part, which should be placed on the heat sink. If Q3-4 is used in the package TIPxxxx, they can be placed directly above the PCB. However, if the transistors are used in the package TO-3, it is assumed that they are connected with short cables at the corresponding positions on the PCB.
Schematic diagram, schematic diagram:
Parts List:
PCB Layout:
Component placement:
Note that this amplifier requires a bipolar power supply. Build the supply using a center tapped transformer with a minimum output current of 2A and an output voltage of 30V, using about 6800uF - 10000uF electrolytic capacitors (elco).
