Parking assist system modification
Source: InternetPublisher:MHD7j Keywords: Parking Assist System Updated: 2025/11/14
Circuit diagram:
Components:
R15_____________3K3 1/4W Resistor
R16___________330K 1/4W Resistor
R17___________470K 1/4W Resistor
R18___________150K 1/4W Resistor
C6______________1µF 63V Electrolytic or Polyester Capacitor
D8,D9,D10____1N4148 75V 150mA Diode
IC4_____________555 Timer IC
BZ1___________ Piezoelectric Generator (Built-in 3KHz Oscillator)
Equipment application:
This modification was designed based on requests: some people prefer audible alarms to visual LED displays, making parking operations easier.
Circuit operation:
The original Park-aid circuitry is retained, but note that the input pins of IC2B, IC2C, and IC2D are inverted. LEDs D5, D6, and D7, as well as resistors R12, R13, and R14, are omitted. The outputs of IC2B, IC2C, and IC2D drive resistors R15, R16, and R17 via D8, D9, and D10, respectively, to alter the time constant of the low-frequency oscillator based on the 555 timer IC4.
This allows the piezoelectric generator to start beeping at a frequency of about 2 times per second when the bumper is about 20 centimeters away from the wall, then increase to about 3 times per second when the distance is about 10 centimeters, and finally further increase the beeping frequency to more than 4 times per second when the distance is about 6 centimeters or less.
- Solving Decades-Old Current Measurement Challenges in 48V BMS Applications
- Lively and interesting bell generator
- Electric vehicle dual power system 48V and 12V application
- Audio Adapter Cable - Upgrading Car Audio with MP3 Player
- Hot wire spark plug control circuit
- Four water tower control schematic diagram
- Homemade disinfectant circuit
- Music calendar using SMC6S37
- GW-0520CH-PS switching power supply circuit diagram
- Nine-digit key code lock circuit
京公网安备 11010802033920号
