Using ATMEL AVR combination lock
Source: InternetPublisher:niV9A Keywords: ATMEL AVR combination lock Updated: 2026/03/27
Code lock based on ATMEL AVR
The CodeLock AVR electronic combination lock is implemented using an Atmel AVR microcontroller, either the AT90S2313 or ATtiny2313. The hexadecimal code program is 2 kB in length. The user code consists of 1 to 4 digits. If you purchase a chip, the user code consists of 1 to 8 digits. If the codes are entered in the correct order, the relay and electric lock striker (in the door) will open for 1 second and then close again. The user code can be changed via a 3x4 matrix keypad. CodeLock keypads can be purchased at your local electronics store. The initial user code (1234) is set via a jumper. The jumper must be inserted before the voltage (12V) connection. The jumper must be removed after two beeps (5 to 15 seconds).
- AVR PC Stepper Motor Driver
- JDM2 PIC 18F Programmer
- PIC Dual-channel Thermometer
- Low-cost AVR programmer
- Parallel Port Controller
- DAC0832 pin diagram and interface circuit
- Design of Simple Digital Voltmeter
- Reconstruction of digital display instrument with single chip microcomputer
- How does MCU handle interrupts? MCU interrupt processing process
- Schematic diagram of MCU SPI interface circuit
- Household combination lock circuit
- Simple phone code lock circuit
- Resistor combination lock circuit
- Three-dial combination combination lock
- Simple password lock
- Telephone dial doubles as password lock circuit diagram
- Novel infrared remote control password lock circuit diagram
- Novel password lock circuit
- Nine-digit key code lock circuit
- Infrared remote control anti-theft code lock
京公网安备 11010802033920号
