Five-band equalizer composed of LA3600
Source: InternetPublisher:清宁时光 Keywords: Op amp low noise Updated: 2021/08/11
The inside of the integrated circuit is composed of five Gaul, low-noise transistors and related internal resistors and external capacitors to form analog inductors with different center
frequencies. There is also an operational amplifier inside as a common amplifier, and the external potentiometer is connected to the operational amplifier through pins 11 and
12. between the noninverting and inverting inputs of the amplifier . Because it can design
a five-band equalizer with different center frequencies by changing the external capacitor, it is very flexible to use. Figure 4-38 is
a five-band equalizer composed of LA3600 with different external capacitors
. Its center frequency is: 100Hz; 340Hz ,1kHz;,3.4kHz,10kHzo
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- 6P3P parallel 20W power amplifier experiment
- TDA2009A power amplifier circuit
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Installing a tube preamplifier in the power amplifier
- A very simple amplifier
- Dual power supply audio power amplifier circuit using LM1875
- Class AB2 Amplifier-McIntosh MC80
- LM4902 differential input audio amplifier circuit
- LM4915 is used for dual-channel amplifier circuit
- Photoelectric isolation circuit design plan
- Squelch Tuned Audio Switching/Mixing Circuit Diagram
- AC voltage current
- Low Power Single Supply Audio Amplifier
- Pulse signal generating circuit a
- Triangular wave oscillator and output waveform using two operational amplifiers
- Practical amplifier circuit f composed of operational amplifier LM386
- Practical amplifier circuit c composed of operational amplifier LM386
- 5V low noise buffer voltage reference circuit diagram using CW136, 5.0V
- MAX8863 low-noise ultra-small 3V linear regulated power supply
