Preamplifier using OP37
Source: InternetPublisher:太白金星 Keywords: Preamplifier BSP line resistance and capacitance Updated: 2020/06/06
As shown in Figure 3-5, this circuit uses OP37 to form a multi-functional preamplifier circuit. OP37 is
an integrated operational amplifier circuit with better performance than NE5534. Table 3-3 lists the parameter comparison between the two. From the comparison in the table, we can see that
OP37 has higher conversion speed, higher open-loop gain, lower noise voltage and higher common-mode rejection ratio, and is
a veritable "King of Op Amp" o
Icl It forms an electromagnetic record player input equalization circuit, which meets the requirements of the RIAA standard. I bar forms a line amplifier,
which provides inputs for turntables, tape recorders, microphones and lines . The input is selected by switch SA. The tone control circuit with high, medium and bass control is composed
of IC3, RP2~RP4 and their resistor-capacitor
network.
The power supply of the circuit uses a 15V positive and negative symmetrical power supply to improve the working performance of the circuit. The circuit components use high-quality resistor-
capacitor components to ensure its technical specifications.
- Simple and practical small amplifier
- A high-quality tube amplifier with 6P3P design
- Installing a tube preamplifier in the power amplifier
- 18-inch large speaker
- The fun of making ISD1820 voice recording box
- Installation of electron tube differential amplifier circuit
- Minimum output noise/reduced output power circuit using LM4910
- Bridge output audio power amplifier circuit composed of LM1876
- LM4903/4905 differential input audio amplifier circuit
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- Ultrasonic blind pathfinder circuit
- Inpatient pager circuit
- Physiotherapy ventilator circuit
- Rice mill circuit
- Diode balanced amplitude modulation circuit
- Capacitive feedback oscillator circuit
- High and low frequency signal generator circuit
- Three primary color display circuit
- Guest arrival signal recognition circuit
- Home appliance repair signal generator circuit
