The equivalent impedance of the amplifier without adding R3
Source: InternetPublisher:smallembedded Keywords: amplifier impedance BSP Updated: 2021/04/09
Capacitor cl shunts the output
signal of the feedback amplifier. In the middle and bass areas, ct is similar to open circuit t and does not
play a shunt role. As the frequency increases, the shunting effect of cl increases,
even causing cl to short-circuit Rt. In this way, the input resistance of the tone circuit will
be reduced from Ri + Rz to R20. Usually R1 is several times or even 1-o times larger than R2. Therefore,
the load is very different from the load in the treble, so that The gain of the amplifier decreases as the frequency increases. Obviously, at treble,
the gain reduction and treble boosting cancel each other out.
- The easy production of several top-quality tube preamplifiers
- Using 6P15 to create an ultra-linear push-pull amplifier
- 6AS7 tube amplifier
- Typical application circuit of LM4903/4905 audio power amplifier
- Class AB2 Amplifier-McIntosh MC80
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- LM4903/4905 differential input audio amplifier circuit
- LM4915 is used for dual-channel amplifier circuit
- Application of BTL power amplifier circuit composed of LM3886
- LM4819 high gain audio amplifier circuit
- High-efficiency speaker circuit for rural stage
- Rice mill circuit
- Greenhouse temperature control circuit
- collector amplitude modulation circuit
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
- Voltage series negative feedback amplifier circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Home appliance repair signal generator circuit
