Diamond differential phase inversion
Source: InternetPublisher:已注销 Keywords: BSP amplifier output power protection circuit Updated: 2021/07/11
We know that under a certain load impedance, the output power is proportional to the square of the output voltage, so under the same conditions , the output power
of the BTL circuit can be up to 4 times that of the OTL circuit.
BTL power amplifier circuit generally consists of three parts : main amplifier , pre-impedance conversion circuit and protection circuit . The
main amplifier has input inversion, voltage excitation, push and output stages, and all stages are connected into a bridge push-pull circuit. Among them, the input
inverter stage circuit uses a diamond differential input inverter circuit, and some use complementary double differential inverter circuits. Because the diamond differential
circuit has special advantages, it is often used first.
- Share a mini piano circuit
- How to adjust the bass and treble of CXA1005
- TDA2009A power amplifier circuit
- Make the most beautiful sound with the least money
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Using Shuguang 350C tube to make tube amplifier
- Electronic bird repeller for crops
- Dual power supply audio power amplifier circuit using LM1875
- 2W×2 power amplifier circuit using LM1877
- LM4915 is used for dual-channel amplifier circuit
- strain sensor
- Excellent performance household inverter power supply circuit
- Bone hyperplasia treatment circuit
- High-efficiency speaker circuit for rural stage
- Straw returning to field crusher circuit
- Greenhouse temperature control circuit
- Mixer built with analog multipliers
- Junction field effect transistor mixer circuit
- Crabo oscillator circuit
- High and low frequency signal generator circuit
