How ALA circuit works
Source: InternetPublisher:常思一二 Keywords: BSP Updated: 2021/06/28
The working principle of this circuit is as follows: the output stage current waveform detection and the original input signal are input into a comparator
for comparison, and the voltage difference between the two is used as an independent distortion signal, which is inverted and then input into the current amplification stage. .
The schematic diagram of its working principle is shown in Figure 1-390. It consists of a distortion detector and an adder circuit. The distortion detector
detects the distortion of the amplifier in real time and filters out the fundamental wave. It is sent to the inverting input end of the adder A3 and added to the original signal of the amplifier .
The sum is used as the coefficient K o. Assume that the final stage The gain is l, and the distortion of the original power amplifier is D, then the distortion D after the ALA circuit
is:
D'=(1-K)D
. Obviously, when K =1, D'=O means zero distortion.
- Share a mini piano circuit
- Using TDA2822 to do direct coupler output experiment
- 75W audio power amplifier made with TMOS150
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Make a pocket amplifier with 8550 and 8050
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Make cheap speakers using waste circuit boards (TDA1013)
- High gain audio amplifier circuit composed of LM4818
- Auxiliary audio power amplifier circuit using LM4732
- Typical circuit of LM4809/LM4810 for dual-channel headphone amplifier
- Smoking Cessation Circuit
- soil content measurement circuit
- Egg warming circuit
- Straw returning to field crusher circuit
- Soil water shortage prompt circuit
- Domestic KD8041 integrated phase locked loop
- Proportional frequency discriminator circuit
- Second-order active band-stop filter circuit
- Three primary color display circuit
- Motorcycle flash light circuit
