Switch noise cut off circuit
Source: InternetPublisher:jikai233 Keywords: noise switch power outage Updated: 2021/03/14
It is the switching impact noise cut-off circuit (the part inside the dotted box).
The low-voltage AC on the secondary side of the power transformer is rectified and filtered by the diode and leads to pin 6 of the IC. According to the internal circuit structure of the STK4101II series IC in Figure 2-81
, pin 6 is the base of the squelch control tube. When a negative voltage is applied to pin 6, the squelch tube is turned on and the bias
control tube is turned off. Force the front stage to stop working, thereby realizing the switch noise cut-off function.
The power supply of this machine does not need to be stabilized, but it is necessary to ensure that the power transformer has sufficient power, and the rectifier component must not be less than 3Ao
- A high-quality tube amplifier with 6P3P design
- Practical and high-performance preamplifier circuit
- Make the most beautiful sound with the least money
- Single-ended Class A amplifier using gallstone composite tube design
- Biliary duct 2A3C Class A amplifier
- Typical applications of optocouplers in audio amplifier circuits
- Stereo tube power amplifier
- LM4902 differential input audio amplifier circuit
- Auxiliary audio power amplifier circuit using LM4732
- LM4915 is used for dual-channel amplifier circuit
- The service life of some components of the switching power supply
- Light controlled safety circuit switch circuit diagram
- Voice recording and playback circuit
- Paper tension control circuit
- On and off states generate fixed-width pulse circuit
- Electric shock debounce circuit
- AC input circuit
- additional preamplifier
- Microphone low noise voice preamplifier circuit diagram
- Audio powered noise limiter
