Homemade multimedia active speaker 01
Source: InternetPublisher:containsmachine Keywords: Active speakers A15 BSP Updated: 2021/02/14
TD A15 24A is mainly suitable for HJ. The DC volume and tone balance control
6 in the Fi audio system avoids the noise caused by directly using a potentiometer to adjust the volume and tone, and only one potentiometer is used to complete the
two-channel volume, tone and balance control. In addition, TDA1524A also has the ability to handle overload of strong input signals
to
avoid overload distortion. For low-level input signals , the volume control button of TDA1524A can also provide a maximum gain of 21.5dB.
LM1877 is an op-amp type two-channel audio power amplifier, which is particularly suitable for use with the TD A15
24A circuit , I. M1877 has a complete output current limiting and overheating switching protection circuit, and is equipped with
auxiliary circuits such as "beep" noise elimination, voltage stabilization bias and mid-point bias, so the LM1877 only requires very few peripheral components to organize High quality Hi-Fi audio power
amplifier.
- Simple and convenient remote control receiver dual purpose detector
- Simple and practical motor short circuit tester
- Design of wireless meter reading system based on DSP
- Infrared detector
- Multi-speed current test circuit of transistor HFE
- How to create a simple oscilloscope using the Basys3 board
- Test of leakage current of switching appliances
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- Geiger counter circuit diagram
- Multimeter DC voltage measurement circuit
- stuttering correction circuit
- Electric massager circuit
- Egg warming circuit
- Poultry warming temperature control circuit
- Biogas concentration detection line
- TDA1518Q power amplifier circuit diagram
- High fidelity TDA1520 integrated power amplifier circuit
- TDA1555Q power amplifier circuit diagram
- High-quality power amplifier circuit of LF356+TDA1514
- Final amplifier circuit diagram using TDA1512
