Full-featured subwoofer power amplifier 01
Source: InternetPublisher:三岁就很酷 Keywords: Power amplifier output power LM3886 protection function Updated: 2020/12/10
Shown are the post-stage power amplifier circuit and the pre-stage signal processing circuit of the subwoofer power amplifier. Here, two LM3886
high-power ICs
recently produced by NS Company in the United States are specially selected to be connected in BTL mode to drive
the speaker with a standard impedance of 8fl. Under the requirement of distortion less than 0.2%, it can continuously output 100W sine wave rated power.
It needs to be explained clearly that I-M3886 is an IC improved by NS Company based on I-M3886. Although its product introduction states that each
IJM3886 can output a maximum 68W sine wave rated power, its internal design has a complete over-power consumption protection function. ,
when used under power supply conditions exceeding 50w output power , it will
protect and cause distortion of the output signal. We should only let it work when the rated output power is not greater than In the state of 50w.
As we all know, slightly better high-power amplifiers are equipped with speaker protection circuits, and the switch that cuts off the operating current of the speaker can only
be a relay contact without any voltage drop. However, when the relay is installed in an active speaker, when the speaker emits a strong low-
frequency sound, the contacts of the relay will vibrate mechanically and cause sound interruption. Therefore, it is not suitable for active speakers with larger power
subwoofers. Using a horn protection relay on the circuit may affect the normal operation of the system. In this way,
the power amplifier is required to have a very complete and reliable safety protection function.
This is also the fatal flaw of using discrete components to make such sound quality. We have reviewed the three subwoofer active speakers produced by YAMAHA and SONY. After conducting actual measurements,
we found that their output power is actually limited to about 50w, and they rarely work in situations with heavy bass. Using the LM3886 power amplifier IC as a subwoofer active power amplifier can take advantage of its complete protection functions such
as overheating, overcurrent, overvoltage, and overpower
consumption to avoid the need for other speaker protection circuits that need to be designed separately. 6 Actual use proof, two The LM3886 power
amplifier IC should be equipped with an aluminum radiator with a size of ZOOmm×50mm×30mm, and flowing air should be maintained on the radiator
. For this reason, the pre-stage circuit and the post-stage power amplifier are specially designed to be separated into two printed circuit boards, so that after the power amplifier board is installed
separately on the radiator, it can be installed inside the box inside the inverter tube. After the 100W sine wave rated output power is
enough to drive the 12Ⅳ caliber woofer to work , we must avoid adding too much output
power to the speaker. For this reason, in the pre-circuit, two resistors composed of R123 and VD117.VD118 are specially designed.
- Make a Simple Darkness Detector Circuit
- Lightweight and practical multi-core cable detection circuit
- Making an Induction Electroscope Using CD4069
- AC ammeter circuit
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Simple password electric lock
- AC equivalent amplifier circuit
- Light Detection 4 to 20mA Current Transmitter Circuit
- Three-phase three-wire active energy meter connected to three ammeters
- Temperature voltage conversion circuit
- TDA7240A power amplifier circuit diagram
- TDA7233D power amplifier circuit diagram
- TDA7057Q power amplifier circuit diagram
- TDA7056A power amplifier circuit diagram
- TDA7052A power amplifier circuit diagram
- TDA2005 power amplifier circuit diagram
- Application circuit of LM3886
- Power supply circuit diagram with overload protection function
- Series voltage regulator circuit with electronic overload protection
- LM3886 typical application circuit
