"Strange trick" amplifier
Source: InternetPublisher:常思一二 Keywords: Power amplifier BSP output impedance AC and DC Updated: 2021/08/07
J.M317 is regarded as a voltage follower with high input impedance and low output impedance
. There is
a stable potential difference of 1.25V between its adjusting pin and the output pin. As long as the audio signal is input to its adjusting pin, the output will be The pin can get the same audio voltage with low output impedance
, which acts as a current amplifier.
The circuit is shown in Figure 6-26. 9 0 1 4 acts as a voltage amplification stage. Because the input impedance of 317 is high, its operating current
only needs 0.6mA. R 1 and C 3 are power decoupling, C4 prevents circuit oscillation, and R3.R4 divides the voltage to provide bias and AC and DC
feedback to
VT to improve linearity and DC stability} R5 has high power consumption and must use
low cement resistors can be competent; it is barely possible to replace it with electric stove wire, but its thermal stability is slightly worse. The power transformer
must have 50w power to have a two-channel shared port.
- How to test whether the multimeter is working properly
- Electromagnetic radiation monitor
- Detection of Bidirectional Trigger Diode
- A highly sensitive human proximity detector
- Simple and practical motor short circuit tester
- Using NE555 to make diode and triode detector
- Multi-speed current test circuit of transistor HFE
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- High current, high power amplifier circuit
- Three-phase three-wire active energy meter connected to three ammeters
- Voice controlled flash LED light circuit diagram
- Physiotherapy ventilator circuit
- Rice mill circuit
- base amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Wien bridge oscillator circuit
- Crabo oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage controlled power supply second-order high-pass filter circuit
- Power phase sequence display circuit
