30Wx2 high-fidelity power amplifier
Source: InternetPublisher:狂妄火龙果 Keywords: High fidelity power amplifier BSP integrated circuit Updated: 2021/11/04
This 30W+30W integrated front and rear stage high-fidelity power amplifier has superior performance and is composed of
integrated circuits for overload and overheating protection . The front stage uses high and low tone control composed of low-noise triodes, and the bass pole is 40Hz. Treble 20kHz, with
20dB treble and bass control + maximum output voltage 1V, input sensitivity about 60mV, suitable for any input
OTI composed of TDA integrated circuits. The power amplifier circuit has an output of
30W+30W at a frequency of 20Hz~20kHz and a power supply voltage of 15V, with a distortion of less than 0.5%. This amplifier is an ideal audio device for the home. The core component of
this power amplifier is the TDA2030A integrated circuit , which has the following features:
(1) Internal Class A and B power amplifier circuit with high efficiency 6
(z) Internal circuits such as output short-circuit protection and overheating automatic lockout. When a short circuit occurs, the circuit can automatically limit
its own power consumption to protect the output transistor at a safe operating point.
(3) The output drive current is large and the output peak current] P-3.5A6
<4) The harmonic distortion is low.
(5) AC distortion is small 6
- Simple and convenient remote control receiver dual purpose detector
- Balcony intelligent invisible anti-theft net
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Fire detector made with photodiode
- Multi-speed current test circuit of transistor HFE
- Inductive Pointer Watch Battery Tester
- A simple electronic muscle stimulator circuit
- Application of TDA1514
- AC equivalent amplifier circuit
- High current, high power amplifier circuit
- Rice mill circuit
- Domestic KD8041 integrated phase locked loop
- Wien bridge oscillator circuit
- Parallel crystal oscillator
- Schiller oscillator circuit
- Broadband high frequency power amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- High and low frequency signal generator circuit
- Sine wave signal generator circuit
