IC temperature conversion circuit capable of linearly outputting 10mV-℃ voltage
Source: InternetPublisher:sigma Keywords: conversion circuit temperature conversion Updated: 2020/05/20
The temperature sensor inside the IC can obtain a voltage output proportional to lOmV/pKR
(2.73V at ooc), and the internal amplifier's 1 line 2_'3 can be pressed!
Can act as a buffer. The function is to use electricity to shift the voltage and I can make the output voltage zero at any temperature
. The malaria transmitter Ic is the 4th, the 1st Genting I battle internal Bentun survey IV ship Qi. !
With a two-channel transistor, the ImA ~ smA voltage
can be
obtained from R: input, which is divided by the variable resistor VRi.
Wen Yishi feels that pPC616A is a compensation type, so
you should pay attention to the inconsistency between the lead numbers and the circuit diagram. As long as you select the components according to the component list, there will be no problems.
- Simple and easy to make zero degree detector
- Convenient and fast power line break detection circuit
- A highly sensitive human proximity detector
- Analysis of valid and fault conditions of differential signals
- 5 tone detector circuit diagram
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- direct coupled amplifier circuit
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- High-speed gain programmable amplifier circuit
- Numerical control following or inverting circuit
- LED lighting display detection circuit with overload protection
- Bus door status detection circuit
- Simple infrared detection circuit
- Using window discriminator as intensity detection circuit
- Level detection circuit using digital-to-analog converter
- Piezoelectric sensor detection circuit
- Differential light detection circuit
- ADM690~ADM695 constitute a detection circuit (2)
- Photodiode pollution gas detection circuit
- Human body detection circuit for infrared sensor
