Simplified resistance temperature measurement circuit using positive feedback method to improve performance
Source: InternetPublisher:ohahaha Keywords: Temperature measurement circuit BSP AI Updated: 2021/12/12
OP amplifier Ai is a box-phase amplification circuit, and a temperature- resistant resistor is connected in the feedback loop . When using smA current for constant current bias, the output terminal of Ai can have
an o. sv (when ooc) voltage. Assume that the change amount of RTD is dchu, and
the change amount of output voltage is ARysm.
The method of A* withering is to divide the voltage of the base stack with on_, 29IPpit, and
then input AS o
about Linear rise problem: It also outputs the partial pressure of Rt and VRi, and sends it to
the inverting amplifier to form a positive feedback, which can be corrected by increasing the RTD bias
The function of the output amplifier 43 is to invert the phase, amplify it 5 times, and adjust the variation range
so that the output voltage is 5v at 5000c.
- How to Measure Turbidity of Liquids Using Arduino
- TC02 temperature measurement circuit
- A circuit for qualitatively testing capacitor leakage
- Making an Induction Electroscope Using CD4069
- How to Use a Radio as a Metal Detector
- An electronic load meter using LM324 operational amplifier as the main control device
- Use LM3915 to make a practical audio power meter
- Test of leakage current of switching appliances
- 3W portable megaphone circuit
- Multimeter DC voltage measurement circuit
- Farmland irrigation automatic control circuit b
- DC ammeter
- Proportional frequency discriminator circuit
- Varactor Diode Frequency Modulator
- Series crystal oscillator
- Schiller oscillator circuit
- One of the double tube emergency fluorescent light circuits
- M50194AP application circuit
- Macro JSYZ5-AI gas water heater circuit diagram
- Switching power supply circuit diagram using FAI3842P
