Complementary differential fully symmetrical power amplifier 01
Source: InternetPublisher:子丑寅卯 Keywords: power amplifier Updated: 2020/02/19
The white input stage uses a complementary differential circuit . On the one hand, it can give full play to
the advantage of the differential circuit's high common-mode rejection ratio. At the same time, the use of complementary push-pull can reduce nonlinear distortion and increase the dynamic range. The emitters of the four differential tubes
are respectively connected to negative feedback resistors , which can reduce the distortion of this stage. Transistors VT5 and VT6 are used for constant current. VT7 and VT8 form a
driving stage. The emitter resistor also plays a role in stabilizing gain and improving linearity . 6. Capacitor C3.C4 can prevent high-frequency self-
excitation.
- Lightweight and practical multi-core cable detection circuit
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Analysis of valid and fault conditions of differential signals
- 3 1/2, 4 1/2 digit intelligent digital voltmeter circuit composed of MAX1492/MAX1494
- Transistor reverse breakdown voltage tester-----Transistor tester
- Inductive Pointer Watch Battery Tester
- Simple and easy to make zero degree detector
- Low resistance connection tester circuit diagram sharing
- High Performance Digitally Controlled Amplifier-Gain Divider
- Sample and hold circuit diagram
- Current amplifier circuit structure diagram
- TDA7231 power amplifier circuit diagram
- TDA7057Q power amplifier circuit diagram
- TDA7056A power amplifier circuit diagram
- TDA2822D power amplifier circuit diagram
- TDA2611A power amplifier circuit diagram
- TDA2004 power amplifier circuit diagram
- TDA1020 power amplifier circuit diagram
- TA222AP power amplifier circuit diagram
- STK437 power amplifier circuit diagram
