Simple voltage controlled amplifier using junction FETs
Source: InternetPublisher:武林萌主 Keywords: Amplifier voltage control FET BSP Updated: 2020/01/10
The basic amplification circuit uses an OP amplifier for out-of-phase amplification, and
controls the amplification factor by changing the voltage dividing ratio of the feedback circuit. If using 'Cvd8'
Rz, set. The resistance value of Rs can be changed, but when using FET, since one end is
grounded, only the resistance value of Rs can be changed. For example, the channel resistance of FET is r. . ,
the amplification factor A of the dizzy circuit is;
ri. The usage range can be from 100 ohms to 10,000 ohms. Assume Ra=iok0,
R!=1kCl,-r,. The range is 50012-skQ. Then ^ can
vary between 2,66~7.6f times.
Since the output characteristics of FET are asymmetric between positive and negative, when AC
voltage is applied to the drain, waveform distortion will occur. This circuit
achieves the purpose of reducing distortion through the local feedback composed of R, and C' .
- How to measure short circuit and ground with a multimeter
- Make a Simple Darkness Detector Circuit
- How to test whether the multimeter is working properly
- Homemade refrigerator monitor
- Simple and practical motor short circuit tester
- A circuit for qualitatively testing capacitor leakage
- Digital strain gauge circuit using MAX1492/MAX1494
- 1.5V and 9V battery tester circuit diagram
- High Performance Digitally Controlled Amplifier-Gain Divider
- Sample and hold circuit diagram
- Excellent performance household inverter power supply circuit
- Analysis of rectifier circuit types and principles
- Self-defense anti-riot circuit
- Rice mill circuit
- Farmland irrigation automatic control circuit b
- Audio function generator composed of ICL8038
- Capacitive feedback oscillator circuit
- Differential Amplifier Circuit
- Color display circuit
- Motorcycle flash light circuit
