Pass the weak magnetic field through a high-gain amplifier that amplifies it 1000 times
Source: InternetPublisher:走马观花 Keywords: Gain amplifier low frequency OP amplifier Updated: 2021/10/24
OP37 is a broadband ultra-low noise OP amplifier .
Good noise characteristics can be obtained with small signal source resistance . We set the amplification factor of the amplifier to 1000
times. In order to reduce power supply interference, a CR decoupling circuit port is added to the power line.
In the low frequency band , if the resistance of the feedback resistor is not reduced, it will be restricted by noise
. Here we select Ri=IOOC>, R2=iOkQ. Since the operating level of the OP amplifier
is very high, there is no need to consider the influence of noise. . The low frequency characteristics are composed of ca,
ugly 5 and mouth. , determined by I, so the parameters of these components can be
selected according to the signal frequency.
- Balcony intelligent invisible anti-theft net
- Detection of Bidirectional Trigger Diode
- NE555 makes a simple and practical acupoint detector
- Leakage Tester
- Low resistance connection tester circuit diagram sharing
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- Simple password electric lock
- Light Detection 4 to 20mA Current Transmitter Circuit
- Phase sequence indicator circuit diagram
- OTL low frequency power amplifier circuit
- Three-phase alternating current detection circuit
- Downhole oxygen concentration detection circuit
- Constant voltage driven bridge sensor circuit composed of OP amplifier feedback loop
- Pass the weak magnetic field through a high-gain amplifier that amplifies it 1000 times
- High stability low frequency crystal oscillator circuit
- Using LM3915 and light-emitting diodes to measure the output low-frequency power circuit
- Compare low frequency active filter circuit diagram
- 5.5W low frequency integrated amplifier circuit diagram for TV audio
- 6W low frequency integrated bridge amplifier circuit diagram
