Low distortion, low noise amplifier for high impedance circuits
Source: InternetPublisher:偷熊计划 Keywords: low noise amplifier low distortion impedance Updated: 2021/11/17
Dual FETs are used in the input stage to reduce bias current and achieve high auxiliary
resistance to meet the requirements of the signal source. At the same time, in order to reduce high
distortion using the Miller effect, it is converted into current in the base ground circuits 5fTr2 and Tr8. control. Since
the current Miller circuit composed of 5fTr' and TrB becomes its load, the collector plate
output can obtain a large gain, and deep feedback can reduce nonlinear distortion. This
circuit is the most commonly used form of discrete component amplifier circuits.
Tr. It is an ordinary constant current bias circuit, and the peripheral bias current resistor R can be said to set
the current exactly. The function of the zener diode Dl is to fix the drain voltage of Trt at
4~5vo.
The OP amplifier is also an intermediate amplifier circuit. Part of it has always been composed of a
transistor differential circuit , but it has been simplified in the OP amplifier.
- How to test whether the multimeter is working properly
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Simple and practical motor short circuit tester
- Analysis of valid and fault conditions of differential signals
- Design of Multi-point Temperature Measurement System Based on DS18B20
- How to create a simple oscilloscope using the Basys3 board
- 1.5V and 9V battery tester circuit diagram
- Light Detection 4 to 20mA Current Transmitter Circuit
- Directly coupled push-pull power amplifier circuit
- Sample and hold circuit diagram
- Woodworking hand planer safety device detection circuit
- Simple infrared detection circuit
- Low noise amplifier circuit composed of ordinary operational amplifier
- Combustible gas concentration detection circuit
- Type A5349 AC Smoke Detection Circuit - Typical Application
- and light detection circuit
- Photodetection circuit for DC recovery to suppress unwanted stable background light
- Differential light detection circuit
- Telephone ringing detection circuit
- Cordless telephone ring current detection circuit
