Typical application connection diagram of TH103
Source: InternetPublisher:三月小雨 Keywords: Trigger wiring diagram diode switching power supply Updated: 2020/03/31
Typical application wiring diagram and recommended parameters: Figure 12-L4 shows the typical application wiring diagram
of TH103 , and its recommended parameters are shown in the figure. Among them, 1. P
is a pulse transformer, and its turns ratio can be selected from 3-2 or Z:l. The +15V and }24V power supplies come from
the DC power supply of the user system, which can generally be a DC rectifier power supply or switching power supply .
The three-phase synchronization voltages are all selected from the secondary side of the three-phase synchronous transformer. The diodes and resistors and capacitors connected to
the secondary side of the pulse transformer are used to complete the shaping of the output pulse and ensure that the voltage at the cathode of the triggered thyristor gate
is reduced . The impedance between them makes triggering reliable and prevents false triggering
caused by interference in the system .
- The meaning and importance of circuit protection, common types of circuit protection
- Car ice warning circuit sharing
- DIY an electromagnetic levitation device
- How to set up a cheap beam break sensor control distance scene using a reflector
- Design and principle analysis of practical electric curtain remote control device
- Design and production of radio remote control fan stepless speed regulator
- Electric vehicle battery charging protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Car audio system anti-theft circuit
- What is the fantasy world of diodes like?
- Analysis of various forms of packaging structures of LED light-emitting diodes
- Analog Circuit--Miscellaneous Talk on Rectification
- Acousto-optic digital level detector circuit diagram
- Photoelectric control electronic birthday cake circuit
- Mobile phone shielding circuit that can be used as a charger
- Photoelectric detection circuit
- PLC input and output wiring a
- Automatic water supply control circuit 2 for simultaneous monitoring of water tower and reservoir
- Diode, resistance and capacitance spark elimination circuitb
