Application of TCA785 in single-phase semi-controlled rectification system
Source: InternetPublisher:他们逼我做卧底 Keywords: Rectifier TCA785 three-phase bridge Updated: 2021/02/16
Used in single-phase and three-phase bridge half-controlled and fully controlled rectifier circuits. Because TCA785
can output two channels with a phase difference of 180 degrees from each other. pulse signal, so it can be easily used
in single-phase fully controlled, single-phase half-controlled bridge or fully controlled bridge rectifier circuits. Three pieces of TCA785 can be used in three
-phase half-controlled, three-phase bridge fully controlled or half-controlled rectifier circuits. middle. Figure 12 10 takes a piece of
TCA785 used in a single-phase half-controlled rectifier circuit as an example to show the application diagram of TCA785
. To simplify the circuit, only one pulse transformer is used in the figure.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design of an autonomous plant watering system using ATtiny85
- How to remotely control devices using ESP8266 and LPC2148
- Use your smartphone to turn on/off the power in your home
- Peripheral circuit of automotive motor controller power supply chip
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Electric vehicle battery charging protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- Magnetic door and window anti-theft alarm
- Infrared detection alarm
- Rural fish farming control circuit
- Multi-channel patrol detection control circuit b
- Simple timing control circuit
- Photocell trigger control circuit
- Electronic rhythm control circuit
- Chicken farm photoelectric control circuit
- High-rise residential walkway lighting control circuit
- Timing and fire power control circuit
- Humidity detection box control circuit in greenhouse
- Two-arm rectifier module three-phase bridge rectifier circuit
