LS7260 three-phase full-wave output circuit
Source: InternetPublisher:newrudeman Keywords: Output circuit motor BSP Updated: 2021/06/16
It shows
the connection method of this circuit with an external three-phase power bridge and current detection. In the figure, VF. ~VF. Indicates the MOSFET inside the circuit for output
driving. Figure 3-6 shows VF, and VF. In the conduction working state, the current
flows through the external transistors V]o, and v, along the dotted line. . the base. The current limiting resistor, R, should
be selected based on V and the required current. When
it is necessary to control the motor to accelerate, decelerate and adjust speed in two different directions,
IoWM circuits such as SG17 31 or UC1637 can be used. The FORWARD (F) and REVERSE (R) pulse width modulation signals they output
can be as shown in Figure 3-7 Connect to LS7260/
LS7261/LS7262. In the figure, a resistor-diode network forms an OR gate logic circuit. When the F
or R signal is high level , the LS7260/LS7261/LS7262 is "enabled", and
when F is high level, the motor generates forward torque, and R is high level. When the cassette torque is generated.
The rotation direction of the motor is determined by the relative ratio of the pulse widths of F and R. The acceleration or deceleration
is determined by the change of these pulse widths.
- A simple magnetic switch circuit sharing
- Car ice warning circuit sharing
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- How to make a wheeled self-balancing robot using ultrasonic sensors
- An automated model railroad layout project using a microcontroller
- Motor control circuit for starting and running without phase loss
- Design and production of radio remote control fan stepless speed regulator
- Design and analysis of the principle of automatic power-off switch during power outage
- Infrared blocking alarm device
- Car audio system anti-theft circuit
- Set timing circuit when power is on
- electromagnetic field sensor
- Inpatient pager circuit
- Junction field effect transistor mixer circuit
- Diode square rate detection circuit
- Capacitive feedback oscillator circuit
- Voltage series negative feedback amplifier circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Small current generator circuit
