PI-AD20 small power amplifier
Source: InternetPublisher:黄土马家 Keywords: Power amplifier PI AD BSP Updated: 2021/11/16
Opening the case, a clean and solid circuit board is revealed. Professional assembly line welding points are smooth and clean, 105'c non-
burned capacitors, ultra-thin dual potentiometers, and professional aluminum radiators. Whether I listen to it with headphones or a small speaker, the sound quality is pure and natural,
the frequency response is broad, and noise is almost non-existent. When connected to a homemade subwoofer, the sound immediately becomes deep and powerful;
when connected to two channels at the same time, it is also very integrated. The market price of this machine is only a few tens of yuan. It is a great value.
The disadvantage is that the stereo headphone output uses M5216 op amp for amplification, and its power is really limited. If you can use TDA2822,
7050T, UI. Replacement of low-power amplifiers such as N3782 will achieve better results
- Make a Simple Darkness Detector Circuit
- How to Measure Turbidity of Liquids Using Arduino
- Balcony intelligent invisible anti-theft net
- DIY Metal Detector
- Make a Economical and Practical Rectifier Voltmeter
- Homemade simple magnetic material tester
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- LM3914 makes car battery detector
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Use LM3915 to make a practical audio power meter
- Set timing circuit when power is on
- AD524 pin and internal circuit function block diagram
- Interface circuit between AD574A and PC bus
- AD574A Unipolar and Bipolar Input Circuita
- Charging circuit personal working principle diagram
- RTD sensor and 24-bit AD7711A circuit
- AD22057 amplifier circuit
- AD22050 amplifier circuit
- AD524 simple thermocouple amplifier circuit
- Precision current source circuit diagram using AD586
