Current feedback power amplifier circuit using LM1875
Source: InternetPublisher:难得正经 Keywords: Power amplifier circuit current feedback LM1875 speaker Updated: 2021/04/02
The current-mode power amplifier has a better listening experience. The current-mode power amplifier circuit using the power amplifier integrated circuit LM1875 is shown in Figure 5-20. In the figure , the resistance R3 of the resistor
t in series with the speaker BL is very small, and the current flowing through the speaker flows through R3. The sampling feedback voltage generated at both ends
is proportional to the output current, and the voltage formed on R3 is sent to the feedback input end of the amplifier through R2, forming a current negative
feedback, which increases the output impedance of the amplifier while reducing the damping coefficient of the circuit. In
the so-called Joubert network, only C4 is used for lead compensation. Although the setting of R2
prevents the output feedback current from being 100% fed back to the negative input terminal, it does prevent
the harmful effects of large feedback amounts on the input terminal; at the same time, t also balances the bias of the positive and negative input
terminals, eliminating the bias of the output terminal. DC offset.
First, solder two small 0.22 r-JI;F capacitors on feet ③ and ⑤, and
solder their other ends together as the grounding resistance of ground terminal 6. They are both bent and soldered at this
point. The ±24V power line and output line are directly soldered to the relevant pins.
Short-circuit the input end to ground. Weld an ion resistor to the position of the BL speaker. Power on and test
the voltage 9 of the output end to ground. If it is less than 100rnV and there is basically no voltage after half an hour. Offset, you can disconnect the input short-circuit and connect the speaker
- Simple and easy to make zero degree detector
- Simple and practical EPROM detection circuit
- Electromagnetic radiation monitor
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Digital electronic thermometer using semiconductor diode as temperature sensor
- Multi-speed current test circuit of transistor HFE
- How to Use a Radio as a Metal Detector
- An electronic load meter using LM324 operational amplifier as the main control device
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- A simple no-load self-stop circuit for welding machines
- Simple 100W power amplifier circuit
- 80W power amplifier circuit
- TMOS75Wx2 power amplifier circuit
- F-9300 power amplifier circuit
- Pure Class B CL power amplifier circuit
- 25W DC power amplifier circuit
- Pure DC FET power amplifier circuit 01
- Make LM1875 sound better
- Headphone amplifier circuit using dual operational amplifiers such as OPA2604
- OCL quasi-complementary power amplifier circuit driven by op amp NE5532
