Power amplifier assembled with TDA1512
Source: InternetPublisher:蓝猫淘气 Keywords: Power amplifier A15 BSP Updated: 2021/02/18
The preamplifier part of this circuit uses the King of Op Amp NE5532* and the tone adjustment part uses NE4558. In the bass circuit,
resistor-capacitance components are reasonably selected and monitored by instruments, which improves 50Hz by 8dB compared to the original design, and has a strong bass effect. Since the treble attenuation is larger when the volume is turned on, the I-,s function is added to the circuit to ensure
balanced high and bass output
even at low volume .
The circuit performance indicators are as follows:
(1) When Uc-±24V, PMPO can reach 2X250W;
(2) Frequency response: 20Hz~20000Hz●50Hz, the bass boost is the largest, optional ZOdB; the treble boost is 18dB;
(3 ) Distortion: ≤0,1%;
(4) Signal-to-noise ratio: 70dB.
When listening to this machine, I felt that the treble was bright, clear, and well-defined. 6. The bass was full and thick. When the bass boost was the largest, it
had the vibration of a heavy bass. When the volume of Shake Effect 6 is turned on low, there is still obvious bass effect.
- Balcony intelligent invisible anti-theft net
- Make a Economical and Practical Rectifier Voltmeter
- Level measurement circuit composed of AD737
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Fire detector made with photodiode
- 4-range digital voltmeter circuit using ADD3701
- How to use STM32 to design an alcohol tester
- Test of leakage current of switching appliances
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- Temperature voltage conversion circuit
- Electric massager circuit
- soil content measurement circuit
- Chicken supplementary light to increase egg production rate circuit
- Rural fish farming control circuit
- TDA1515B power amplifier circuit diagram
- Application circuit of TDA1524
- TDA1516 two-channel power amplifier
- TDA1552Q power amplifier circuit diagram
- TDA1555Q power amplifier circuit diagram
- CA1524 push-pull converter circuit diagram
