Simple lithium battery charger circuit principle
Source: InternetPublisher:黄土马家 Keywords: Lithium battery charger circuit principle charger circuit Updated: 2020/05/04
The picture shows the circuit principle of a simple lithium battery charger . After the 220 V AC voltage is stepped down by capacitor C1, rectified by diodes VD1~VD4, and filtered by capacitor C2, the charging current is limited to about 70 mA. When the battery voltage is lower than 4.2 V, ZD is turned off and all current is charged into the battery. When the battery voltage rises to 4.2 V, ZD begins to conduct and play a shunt role. Since the charging current is smaller, the charging time is longer. In the circuit, the resistance accuracy of resistors R2 and R3 is required to be very high, with an error of 1%.
- The basic principles of power supply design. What are the key components of a power supply?
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Introduction and principle analysis of switching regulated power supply
- Simple and practical LED lamp driving circuit
- LNK304 non-isolated LED light string driver circuit
- Current/voltage conversion circuit using current converter
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A novel and practical DC low voltage stabilized power supply
- Electric bicycle battery charger circuit
- Homemade Electric Bike Fast Charger
- Smart charger circuit using BQ24721 chip
- Lithium battery charger circuit
- Nickel cadmium battery charger circuit 2
- Design a high-quality battery charger circuit using PS1718
- Multifunctional automatic charger circuit
- Walkie-talkie fast charger circuit
- Lead acid battery charger circuit
- Wind energy battery charger circuit
- Automatic stop charging battery charger circuit
- Constant voltage current limiting charger circuit
