Application of L295 in four-phase stepper motor drive
Source: InternetPublisher:偷熊计划 Keywords: Stepper motor drive valve Updated: 2021/02/12
The overheat protection of L295 is to turn off the switch when the chip temperature exceeds 1500C.
Due to the hysteresis circuit, the temperature drops to about 1300C and returns to normal state.
1_295 can be used for various inductive coil controls , such as valve solenoids, printer print
heads, stepper motors and DC motor drives. By controlling the vREFta level , the valve
can be accelerated with a higher starting current and then maintained with a lower current. Figure 11
25 shows the connection diagram of the unipolar drive of the four-phase stepper motor. Rtr can also be used as a stepper
motor to select different amplitude currents at different operating speeds. When the stepper motor at this coordinate
does not move without command pulses, a lower holding current can be used . L295 can also
change the connection method to obtain H-bridge driving mode.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Squirrel cage asynchronous motor reverse braking control circuit
- Add one more component to improve the phase failure protection function
- Design and analysis of voice control circuit
- Do-it-yourself trial production of phase failure protection device
- Design and production of no-load automatic power-off device for household power supply
- Homemade anti-theft watchdog
- Car audio system anti-theft circuit
- Rural fish farming control circuit
- Electric plow control circuit
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- time control circuit
- Paper tension control circuit
- Infrared voice control circuit
- PLC light source robot hand bubble control circuit
- Photoelectric detection output control circuit
- Forward and reverse control circuit of micro DC motor a
