LMD18200 is used in speed regulation
Source: InternetPublisher:酷到被通缉 Keywords: LMD18200 BSP current detection Updated: 2020/05/16
Input control signals include direction (DIRECTION, pin 3), brake (BRAKE,
pin 4) and PWM (pin 5). PWM control can be used in two ways.
Mode 1: The PWM signal is input from pin 3, and pin 5 is connected to high level. A so% duty cycle
PWM signal corresponds to zero drive, and the average load current is zero. The PWM signal with a duty cycle greater than 50% corresponds to the forward current, and the load current
flows
from pin 2 to pin 10 .
A PWM signal with a duty cycle less than 50% corresponds to a negative current
flowing from pin 10 to pin 2.
Mode 2: Pin 3 inputs the symbol signal, logic 1 represents forward direction, logic O represents reverse
direction. Pin 5 inputs a PWM signal, and its duty cycle is proportional to the load current.
I, MD18201 has similar functions. The difference is that there is no internal current detection ,
which can be replaced by a current detection resistor connected in series to ground on pin 7, and pin 8 is changed to logic ground.
Figures 11 17 and 11 18 show
the schematic diagram of the integrated circuit applied to DC motor torque regulation and speed regulation. PWM control adopts mode 1. The LM3525A in the picture
is a general-purpose PWM controller. In the torque adjustment diagram, pin 8 leads to the current detection
signal to provide torque feedback. In the speed adjustment diagram, a DC tachometer generator is used to provide
speed feedback. Its speed sensitivity is 1V/(r/min).
- Design and selection of electric control valve system drive
- Tutorial on making your own remote-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- DIY an electromagnetic levitation device
- A small improvement on the ordinary refrigerator motor starting circuit
- Hydraulic control circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Infrared blocking alarm device
- Homemade short circuit alarm device
- Precious home appliance anti-theft alarm
- Bone hyperplasia treatment circuit
- Pulse therapy circuit
- Smoking Cessation Circuit
- Particle clogging alarm circuit of wheat seeder
- Biogas concentration detection line
- Farmland irrigation automatic control circuit a
- Amplitude modulation circuit composed of MC1496
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Sine wave signal generator circuit
