Eight-way flashing light string circuit
Source: InternetPublisher:方世玉223 Keywords: Flashing light BSP radiator Updated: 2021/08/24
It is a practical eight-channel flashing light string controller with large output power, and the driving power of each channel can reach
1/)OOW. It is suitable for shopping malls, hotel facade decoration and outline light control of tall buildings.
Guzhong SE9'2. I
is a bipolar
human-scale integrated circuit with L and M()S compatible processes
available from
Henan Xijin Jubao Electronic Manufacturing Co., Ltd.).
It adopts IP-IS packaging
and can also be customized according to customer requirements.
Users need to customize the Heiken soft
package. There are very few peripheral
components to modify the chip. The instrument requires a resistor RP and a capacitor C:, whose resistance and capacitance values determine the clock frequency of the oscillator. The normal
electric cell value is 0.1--0.22yF, and the resistor is a 1Mn variable resistor. By changing the resistance value,
the flash speed can be changed. When the ideal j-light frequency is adjusted, the same resistance value can be used. Resistor. The circuit has four pattern transition terminals R1 -1{4.
Through their different level connections, numerous changing flash patterns can be formed. See details in Figure 8-5.
The chip has eight QI-OS input terminals, which can be connected to drive low-power thyristors to drive eight-way colored lights to flash. According to the circuit,
eight 9013_ triodes of Ql--Q8 channels VTI-VT8 drive eight high-power thyristors VTHl-
VTH8 (12A, /t300v), and push the eight-foot colored lights Fl-E8 to shine (to simplify the drawing , only the mountain El,
E2 and E8 roads are drawn in the middle of the week, and the other roads are the same). The pattern twisting plate mainly consists of several strong switches
connected in i/l rows according to the requirements in Table 8 and 5, and then a small pattern cycle can be obtained. Eight
light-emitting tube should be installed on the panel of the controller ff/l'caizhou circulating electric bright finger/i (their Shiny
and colorful at the same time).
Ding should use j 220V, 6 3V, SVA small §u high-quality power transformer, which is required to be turned on for a long time without generating heat.
VTl-VTS u』H1 ordinary 9. 1:1 type silicon transistor, requiring p-]0{1. VrHi_vrH8 eight high-power H thyristors are required to be equipped with an aluminum radiator
with sufficient area . Thermal conductive silicone grease is applied at the contact surface between the radiator and the thyristor
to enhance heat transfer. This motor generally does not need to be debugged and operates normally. For high-power drive circuits , light fluctuations sometimes occur. This is caused by the high-power thyristor not being fully conductive. This can be solved by appropriately
reducing its current limit (i.e. R-~S). If necessary The crystal tube can be replaced at any time. If the power is normal just after startup, but
after working for a period of time, a certain light or a few lights are always on, it is usually caused by the use of inferior quality gate tubes or
the insufficient area of the radiator, which causes a temperature rise. If it is too high, the solution is to replace the inlet pipe with a better quality one or
enlarge the radiator .
- A white light LED power outage emergency light
- Laser detection and indicating device system circuit design
- "OR" logic element configuration circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Power outage emergency lighting
- One of the bead-type emergency light circuits
- Simple light-controlled street light circuit (7)
- Temperature control alarm circuit
- SH-803R holiday lights ASIC
- Simple sensor alarm
- Motor overcurrent protection circuit
- Voice controlled flash LED light circuit diagram
- Smoking Cessation Circuit
- Fish pond oxygenation reminder circuit
- Rice mill circuit
- Biogas concentration detection line
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- Capacitive feedback oscillator circuit
- OTL low frequency power amplifier circuit
