Discrete component sound and light control stair delay switch circuit (10)
Source: InternetPublisher:通通 Keywords: Discrete components switching circuits light control Updated: 2020/12/04
It is a sound and light controlled stairway delay lighting switch that uses a positive feedback audio amplifier. Its
sound control sensitivity is relatively high. At night, ordinary conversations or footsteps can trigger the light E to light up.
The basic principle of this circuit is similar to the above example. VTI-VT3 constitutes a positive feedback audio amplifier. As long as
microphone B senses a weak sound wave signal, Vding3 will quickly cut off, its collector potential will rise, and VT5 will be turned on.
The 12V power supply charges ' through wrs and VD2, and its subsequent circuit is exactly the same as Example 159. VT8 is turned on,
and the lamp E is powered on and emits light. In order to make the light control performance of the circuit stable, compared with Examples 1, 5 and 9,
a separate light-controlled electronic switch tube VT4 is added to this side. VT4 is turned on during the day, and the base of VT5 is short-circuited to ground to make it have no output.
Only in the evening, when VT4 was cut off, was the blockade on VT5 lifted. This circuit works stably and has
good performance. The requirements for components are the same as the above example. If necessary, the bias resistor R of the VTI needs to be adjusted. ,
just make the gain of the positive feedback audio amplifier appropriate.
- LED acceleration and deceleration motion display composed of CD4017
- USB powered portable light
- A light fence circuit diagram with LDR
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Application circuit of CAT3606
- Large light emitting diode display circuit
- Fluorescent lamp dimming circuit composed of thyristors
- Fluorescent dimming circuit (1)
- Small current anti-theft alarm circuit
- Four color light circuit
- Light controlled delay circuit (5)
- Digital circuit sound and light control stair delay switch circuit (5)
- Discrete component sound and light control stair delay switch circuit (2)
- Use NE555 to make light-controlled flashing warning lights
- Color light ring flash controller circuit
- Using ER1211 ASIC as automatic exposure controller circuit diagram
- Signal circuit using light-controlled relay to control thyristor
- Homemade light-controlled LED lighting circuit diagram
- Light controlled automatic night light circuit
- Light controlled oscillator circuit
